The 64 Cyclone was slated to received the 289 HiPO thus the K stamping. It was killed by Iacocco prior to final production. The actual engine that took its place was the D Code 210HP Low Compression 289 4v from the Mustang. The only difference in the Mercury was the larger 1.12 600 CFM Autolite carb, as opposed to the Mustangs 1.08 480 CFM Autolite carb. The A code was not introduced until later in 65 with 10:1/225HP 6 bolt vs 9:1/210HP 5 bolt for the D code.
