Hello, I have just purchased a 68 Cougar and am having difficulty with the turn signals as most have apparently. I have read alot of the tech stuff from this site and the net and have still to figure out what is going on. I'll tell you what I know so far.....
Brake lights work fine..... running lights work fine.
Dash lights turn on, but don't flash...... Four ways turn on, but don't flash.
No flashing lights on the exterior of the vehicle, no lights come on when turn signal depressed in either direction. (on exterior of car)
When I bought the car, the owner had already purchased the electronic replacement for the sequential flasher part of the "bits in the trunk" (the white box half).
I have replaced the white box with the new electronic unit and nothing has changed. I have noticed however that the trunk is missing the emergency relay and there is just the 5 prong female connector and ground plug coming from the harness of the rest of the units in the trunk. Is this required to be there for this system to function properly?
I was about to go online and purchase the "complete replacement" for the units in the back (C8WY-13A366-AS ) but am kind of hesitant as I may only need the emergency relay as it is missing. (emergency relay is only $40 compared to the $200 for the complete replacement of everything.)
Any suggestions would be greatly appreciated and helpful.
Cheers!
Goose.
Cheers!
Goose.
