1 - 2 of 2 Posts
Just want to be sure as I finalize the re-wiring here. The wire that runs from the firewall connector to the coil is simply a turn on wire for the coil (ignition switched). I want to use the same circuit to turn on my 3 wire alternator and operate the electric choke. Anyone see any problems? What gauge wire would you reccommend?
The wire to the coil is a resistor wire.If you want to use that circuit run a new wire to the ignition switch.
Bruce
1 - 2 of 2 Posts
