I'm thinking about changing my carb for my first
winter project.
I need lots of help because I'm just a new gear head.
Right now my car is pretty stock:289 2v 33k miles.
I do not want to build a racer i just want better
preformance. I also need one that is easy to install.
the HOLLEY carbs say" bolt it on and go".
Is this really true???
thanks for any and all info,
Jim
Super Moderator
Jim,
I used a Holley 500 CFM 2V carb on many of my Cougars with 289 and 302. It is a bolt on and go proposition. It fits your stock intake and gives a substantial boost in performance.
I have also tried the 350CFM 2V Holley and find that it is no different than the stock carb in performance.
Royce Peterson
Edelbrock also makes a bolt on 600cfm that's pretty easy to install
I have much experiance with the 4412 500 2bbl holley and I would advise against it. Its a great carb, but a small 4bbl would be a better fit for a street car with better all around perfomance and especailly with regards to fuel economy. Also the 4412 only comes with a manual choke.
That said, the only draw back for easy instalation for the 4bbl is the need and expense of changing the intake manifold but 289- 302 intakes are easy to come by either new or used.
If your dead set against changing manifolds I would just use the holley 350.
A eldebrock performer with a 600 holley single feed, vac secondary,electric choke carb would be pretty easy to install and setup actually. Or you cant go wrong with a 600 eldebrock carb either. They are pretty much bolt on and forget them.mm
