What size wheels should I put on my 68 Cat? 15, 16, 17? I am building a daily driver engine is putting out just under 400hp. Gonna be a daily Driver
I have the will Dyno it before they ship it with verification that it puts out the specified HP. I am Buying from Proformanceunlimited.comCheck that company's stats on the engine...being the machine work, crank, pistons, rods, heads ect for verification of the horse power. Also, 17" wheels are easier and cheaper to find wheels for, but I'm old school and love 15"s which is what I chose.
I like the 15's myself. I hate massive wheels I think they look stupid on classic carsCheck that company's stats on the engine...being the machine work, crank, pistons, rods, heads ect for verification of the horse power. Also, 17" wheels are easier and cheaper to find wheels for, but I'm old school and love 15"s which is what I chose.
Thanks for the advice. Does anyone know where I can get a good set of paintable rims I want to paint them to match the Lines and not chromeI have 255/50/16's on the back of my 68, they fill up the rears nicely. 225/5516 up front, and my car has manual steering..... I got the 16's at a swap meet for cheap, they are getting very common, and much less expensive tires than a "performance" 14...
My fear is that it will rub the fenders. Does it? or do you have to do anything special to keep it from doing so?I wanted 15's as I am kinda old school too, but when I looked at available tires I saw the writing on the wall. Went with 17's and am very happy with them, they do not look too big and the brakes don't look too small with the wheels I chose either. It is of course a personal choice as others have pointed out, but at some point one needs to look at economics and current availability and factor that into your decision, that is what I did.
That should be no problem, as long as the width and the backspacing is fine, when you go to from 15 to 17 wheels, you also go down on the profile on the tire so the diameter on the tires are the same, just as an example, 225/60X15 to 225/50X17, just look around on several of the wheel/tire sites, they usually have a wheel/tire fit calculator witch shows how the different diameters is with different sizesMy fear is that it will rub the fenders. Does it? or do you have to do anything special to keep it from doing so?
My rear 285/40-17's on 17 x 9 with 5.25" backspacing are PERFECT with no issues, my front 245/45-17's on 17 x 8 with 4.5" backspacing are close but I have no problems to speak of with them either!My fear is that it will rub the fenders. Does it? or do you have to do anything special to keep it from doing so?
LOL, so having rims you could not get tires for would okay then, huh? :buck:Tire availability would not predict my wheel size, but I'm on the old school side. 15's for me.
