Ok, simple question for the majority of you, but I want to get it correct.
As far as wheel sizes, lets take 15x7 -- The 15 is the diameter of the wheel, and the 7 is the width from outer to inner lip -- correct?
I have the backspacing down. You can use spacers if more backspace is needed, any rules to follow here?
Bolt patterns, lets take 5 1/2 -- Is this the distance from the center of the rim to the center of the lug hole?
I have seen on ebay the universal wheels, also read that you should stay away from those right?
What about RWD wheels, is there a difference from regular wheels?
Lastly, what's the bolt pattern for a 68?
