Hey guys whats the firing order on a 68 302 engine i have two books and both are the not the same ?.i still have the problem with the slow crank there is no juice (electrical).when you turn the key to the on postion there should be power at the postive side of the coil?well there is not. when i crank the engine there is.. more info it has a rv cam and i still trying to time it.whats the best way to get rid of water in the engine? flush it.seems some water found it self to the oil..i was going to change the oil once the car started
maybe have to change a few times to get out all the oil> ok guy i will wait for the help..thanks
