There is a small notch at the bottom of the water pump mount surface on the timing cover. Won't water leak from here? I assume that I am to make sure the Permatex fills this void.
I know this is where it leaks when the water pump "goes"
Is this notch serve a purpose? Should I just make sure it gets plugged?
