Just in case you get lost here's a few ideas. Dying is pretty easy but you have to remember to clean the vinyl and plastic thoroughly with the appropriate cleaner. You need to remove all oils and especially the residue left by Armorall and other protectants.You can have almost any stock or custom color dye mixed by most automotive paint suppliers and spray it yourself with the $4 "do it yourself" sprayers found at most hardware stores. Or you can use the canned variety from the auto parts stores. If you follow directions, things should look pretty good.
