The console sliding door on my 67 Cougar is hard to open. Where the handle is, it's already a little bent from the previous owner. Back in the stone age, when I had my first Cougar, I busted the door trying to open it, and all the little slats came apart. What can I use to lube the track for the door? I thought of white lithium grease but before applying I wanted some advice. THANKS
I used general suspension lubrication, applied very carefully with a Q-Tip.
A good soap and water clean of the track and slat edges, then apply a graphite powder after completely dry.
What about a silicon spray? Mines a lil' stiff too.
After 45 years of spilled soda, coffee, food particles, dust, cigarette smoke and or exhaust fumes. A good cleaning with soap and water will work best. I would not put a liquid lube on something that is already sticky. Another thing to look at is; has the console shrank from UV or floor heat and is now compressing the slat door in the track channel?
It's the backing rubber that sticks, making it hard to open. And the angle that the door folds back under the dash doesn't help. I tried the vasoline trick and it slides nicely up and down. Hmmm, slides nicely up and down, maybe I should have used K-Y!
