1 - 8 of 8 Posts
Upper red hose. Some kind of port to close/open water to the heater?
It seems to be vaccum regulated.
In what purpose, is it stock or after market?
:confused: / Tommy.
Heater control valve. Shuts off hot water to heater core when air conditioner is turned on.
Where does the other end of the vacuum hose connect?
Ok, thanks, never had a AC car before. The other end connect to the carb vaccum,,, i think.
/Tommy.
Vacuum controlled valve that activates when car AC is on to prevent hot water circulation through your heater core. This valve in the picture is after-market, not original. I believe you will find a vacuum switch under your dash on the heater core plenum that is activated by a cable from the heater/AC control unit.
:confused: / Tommy.
I have that same valve on my 68 390 X code. It is factory installed.
Thanks again, didnt investigate to much where the vac hose is attached, its ruted in front and under the airfilter. I assumed that it was connected there.
Now i know what it is and the reason.
/Tommy.
1 - 8 of 8 Posts
