So I have been redoing my 69 convertible a little at a time. Last week I decided to pull the dash out and correct a couple of wiring issues the p.o. caused. Take out the alarm, correct a couple of clipped wires, that kind of stuff. I also replaced the speedo cable while I was in there and I epoxied the contacts on the PCB down as they were lifting. I also gunked the engine to clean it off a bit. The dash and instrument cluster are still out. I jumped the tach, started the car and dried the engine... Sunday, I went out an replaced a ground wire from the alternator, got in the car and it would not start. Turns over, has 12.5 volts to the primary when the ignition is "on" if I go to ground and 5.5 volts if I go across the coil. When I crank it, I get nothing. Though I flooded it, but I have waited a couple days and I still get nothing, not even a cough. I thought it was the relay for the alarm causing the problem and I took it all out and followed the schematics to ensure I hooked the wires up correctly, but I still get nothing.
Any ideas? Could the coil ground out when I go to start? Also are wires 32 and 32a the same color? I couldn't locate 32a's color anywhere.
