1 - 10 of 10 Posts
Question
Can someone tell me what is the weight of a harmonic Balancer for a 67 cougar w/ a 289?
Thanks in advance.
Not sure of the exact weight, around 5 pounds I would guess. You can use any of the three bolt pulley equipped harmonic balancers, all have the correct imbalance for a 289/ 302 / 351W in the pre - 1970 modle years.
Was the question for actual weight, mass weight, or imbalance weight?
School me on this guys, I had been led to believe that the 28oz and 50oz imbalance thing pertained to the flexplates/flywheels?
Crankshaft dampeners or crankshaft balancers, are all different for pretty much each engine, each year.
School me on this guys, Crankshaft dampeners or crankshaft balancers, are all different for pretty much each engine, each year.
I found this on the web so it has to be true. I have a shudder in the engine on my mustang that used to have a 260 from the factory in it. It somehow wound up with a 289 in it. In my research to resolve this very very mild shudder I came across this:
http://www.fordsmallblock.com/PDF/SmallBlockV8Balancing.pdf
It shows what you are in question about....also I discovered my 289 has a 260 harmonic balancer and who knows which flexplate. I will swap out to a 289 balancer next and if the shudder does not go away I will be IDing the flexplate and fixing that if needed.
John
hi there..I have a quick question about the weight of the stock harmonic balancer. What exactly is the weight, I searched on the forums and did a quick google search but found nothing.
1 - 10 of 10 Posts
