Well, after changing my ignition switch, door locks, battery, a donut gasket, and working a bit on the electrical, I took the cat for a spin last evening. I started noticing a squeal coming from under the hood. After getting home and listening a bit more, it sounds like the water pump is sqealing/grinding, I guess it is the bearings going out. Does that sound right? Could anything else be doing it? At idle, it isn't that bad, but if I hit the gas, or stay at sustained RPM's, I can really hear it. My belts are nice and tight by the way. And it isn't overheating...yet. Any thoughts?
