Status
Not open for further replies.
1 - 20 of 28 Posts
Banned
so the parts store cannot seem to find me a 351w pump w/o heater hoses lines on it, and my engine also has them, so which ones are better to use? :bloated: block or pump lines?
Banned
i need to know what was stock? using the ones off the pump, or off the block. on the block i have one on intake and one on thermostat housing and also one on the lower right front of block, then 2 on the pump :bloated: so what goes where?
There should be a short elbow hose called the bypass hose that goes from the water pump to the thermostat housing. The heater hoses themselves go from intake manifold to heater core, and the other from water pump to heater core.
Banned
ok ok so whats the one for on the lower right corner of the block? theres an outlet that used to have a heater hose on it. weird, i think ill just cap it off.
There is a short lie from the intake manifold to the water pump. It serves the function of bleeding air out of the heater and engine, and you need it.
Lower right (passenger?) corner of the block? Pics would help!
Banned
same position as the fuel pump but opposite side, its a water port with a 5/8 nipple for a hose. never seen that before.
On a '69 351 W the radiator return hose is located on the lower right hand side of the water pump. Is that what you are seeing?
You may have the wrong water pump..
Need pictures or a Shrubbery.. maybe both.
Seems to me that a 351W and a 289/302 are about the same. If so here is a pic of my 68 302. If they are different my apologies. The small 90 degree elbow hose is hidden by the upper radiator hose but you can see the bottom of it. Hope this helps.
Chris
Banned
Discussion Starter #15
thanks, here is a pic of a racing block but i circled where i have the water outlet on my block. this block is from a 68 fairlane and i guess only made for like 1-2 years and has different things on it so who knows. ill just cap it off again.
The hole in the side of the block is where the negative battery ground cable is attached to the block with a large bolt. This is not a water outlet location.
Banned
Discussion Starter #17
as i said, on mine it was capped off with a heater hose and plug. i removed this and water pours out. its NOT a threaded hole, its a water port. maybe on other blocks its a bolt boss but not on mine.
Marine block? Post a picture.
Digital cameras are inexpensive.
1 - 20 of 28 Posts
Status
