I am new, Just got he 1974 XR7 in gray. The worse is under the vinyl. I am thinking to remove the cover. Repaint with the wrinkle paint I have seen. Has anyone thought to do that instead of putting the water collector back on?
Ok, I figured it out. Pull the rubber out of the channel and there is screws under it. Remove that bracket. Then the screws holding the drip rail are exposed.
The worse rust is around the rear window along the bottom. About half of the window channel is gone. Guess, next will be to remove the window and see how I get replace the section.
