Does anyone know of a shop that can replace the little studs on the convertable chrome trim that surrounds the top?
Randy, I don't think the studs are 1/4-20, think they are more like 10-24 or 8-32 (probably the former?). You did not mention how you attached them, drill out (not too deep!) and tap. You can do this most of the places, but not so much on the ends (of XR7 moldings). I was able to do 2-56 on two of the three and used "Goop" on the very end one, too shallow to drill.
Hope this helps the thread poster.
unfortunately the previous owner of my 70 XR7 convertible decided the best way was to drill a hole through the trim and use a self tapping screw. Lucky it is only on the end near the door and it doesn't look too bad if you use a polished stainless screw
Sounds like there is some demand for a shop with the expertise to repair these. they look to be welded in place?
