Anyone know how to get the vent window handles off my 68? I read that there is a little pin in the hole in the handle, but I can't seem to drive anything through the hole - and the other one I can see right through it. Any hints?
If you can see right thru the handle should pop off with a little prying using a flat blade screwdriver. It takes a really small pin punch to knock out the pin.
Get yourself a 1/16" pin punch. That'll do the trick.
