Okay, did a lot of sorting tonight and here is a bunch more stuff:
2) Exterior windshield trim header pieces. All SS is good restorable condition with no dents
3) DS windshield vertical trims
1) PS windshield vertical trim
1) Rear window trim set
1) FMX inspection plate
3) Vinyl top moldings, PS side and both backs. Few broken studs
2) (69) Hood latches
2) (69) Hood latch brackets
Radiator support hood bumper brackets
1) Cowl grate
1) Rear bumper core (good restorable)
351 Engine frame mounts
Rear axle housing, 2.75 open carrier and associated parts, pm or post needs (not selling complete)
Emergency brake cable set, restorable
2) Front sway bars, stock size
1) '69 vacuum tank
2) '70 vacuum tank, restored
351W AC idler (three hole mounting)
Shock tower caps
Disk brake dust shields
PS quarter extension, replacement style (no rubber insert groove)
Headlight assembly harnesses
2) Glove box doors
Caliper cores
2) (sets) Shock tower braces
AT Power brake pedal
Rear frame rail differential bumpers
FMX kickdown tube
2) Tubular front frame braces
Alternator cores (numerous)
Door window bracket guide tubes
Shipping tiedown brackets w/bolts
Steering box core (seized)
Trunk hinges
Wiper transmission (good)
3) Wiper motors
Cowl steering column brackets (attach column to lower dash/cowl, sheet metal and rod)
'70 Tie rod set and sleeves (good rebuildable, need boots)
'70 drag link
'69 drag link
Axle isolator brackets/rubbers
2) (sets) Coil spring covers (in fender well)
2) AT floor shifters
2) FMX shift linkage
2) FMX trans crossmember
1) Vacuum booster spacer
XR7 Clock mounting bracket
Door latches
OEM 3 speed manual trans shifter and arm, linkage
Dash map light
More to come PM or post interest and/or requests/inquiries
