I am trying to get my headlights working correctly.....I found a diagram showing 2 vac lines going to the cannister under the drivers fender. I have 2 hoses but only one connection at the cannister.....One of the hoses is plugged... Is there a special fitting or something ?? Any help appreciated.......
What year? 69/70 only has one connection at the canister and two lines run to the vacuum motor.
68 only has one line to the vacuum canister and two to the vacuum motor also?
I believe 67 had two hoses and fittings at the canister, the others 1. I'm thinking you have a 67 car, 67 diagram, and a '68 canister. You could fit a section of hose to the canister. The other end of the hose with a T or splitter that you would connect the 2 hoses from the car.
The single fitting reservoir and separate check valve were used to replace the double fitting reservoir which came with a built in check valve. I hope this helps.
