1 - 13 of 13 Posts
1968 Cougar 302" Engine has less than a 1000 miles on it. New exhaust system
Built by Engine Performance Center
Installed a Comp Cam Receipt said Com 31-218-3
Emailed Comp they said no such number I did a search
and they make a 31-218-2 cam ,so maybe it's a typing error.
Comp says 31-218-2 will not effect the vac
Specs:Stock timing 6 degrees Dwell 30-33
I set the timing at 12 degrees Dwell 30 may have to retard slightly
Question: I blocked off all vac hoses and the manifold reads 13½-14"
What is the best thing to use to check the manifold leaking? And carb
to manifold gaskets?
I checked the manifold bolts
I don't want to start a fire, carb cleaner?
The carburetor is an exchange rebuilt
I had similar experience with rebuilt carburetor. After much frustration I found that the engine was actually running on leakage through the secondaries, no vacuum & no way to adjust idle either. New Carb solved the problem.
Thanks anyway,I replace it with another Carb I had in the lawn house,reads 14"
What type of intake do you have on the car ? a single plane produces less vacuum than a dual plane intake.
All I know, it's a stock manifold,we bought the car in 1983 ran great
After we installed the rebuilt engine with a mild street cam, my brakes were lousy
low vacuum issue. I installed a Crane reserve system to compensate but
I still would like to find the cause. Thanks
You have another thread going on at the same time. Well your vacuum is exactly what I would expect from that cam. That is all I got from mine once the timing went to 15 initial. At 10 initial the car had 8 mmHg. So I don't think you have a leak.
One thing I found out about about our 302s was to look inside the distributor to see what the setting is. I was surprised when I saw that my J code had only 20 degrees mechanical. On top of that Ford said to use 6 initial which gives a total of 26 degrees??? Unbelievable. I immediately moved my initial to 15 degrees to get within the 32-36 degree range for a high compression engine. What a difference that made in all aspects. Retarding your timing is not what you want to do to help out your vacuum.
Got to have more initial timing than stock with a performance cam.
99% sure if you put the initial timing around 15-17* your vacuum will increase and the car will be MUCH more drivable.
Now I am confused I set the timing to 12* and was told to set at 10 (stock is 6 degrees)
To set it at 15-17* I'll have to pull the distributor and move away from radiator
hose. I would do it,but how do I tell when it's to far advanced?
Pinging? Light/heavy throttle? Thanks
You want the most advance the motor can use without pinging.
On stocker distributors I modify to limit the total advance to around 40* so I can set the initial high enough for the engine to idle OK but not so much total advance that the engine will ping.
If you can't adjust to 15-17*BTDC your distributor is installed wrong anyway.
Discussion Starter #10 (Edited)
Gain 2hg vacuum
You were right Art,started at 17* full throttle, bump it up, big difference no pinging
checked @ home 21* leave it there. Thank you my friend.
Cool, you may want to tweak the timing from time to time but as long as the motor starts easily and not pinging you're golden!
How is the timing on the cam set ? that cam has 3 positions, retarded, 0 and advanced timing, usually it´s the straight up, 0 setting that is used.
Discussion Starter #13
I didn't build it but I'm starting to catch on.
Right now I don't know if that is the case or the harmonica balancer was built wrong.
Anyway maybe I'll do some more pull tests-bump it up some and retry until I hear it
pinging. They built the engine in 1998 and no longer in business, I should have gone
back to them for more Info. Wife's car and I was to busy.
1 - 13 of 13 Posts
