How does the vacuum hoses attach to the wiring harness on a 70 model? I know that the 69 had plastic clips that they both went through but the 70 has the clips made in the harness? What did Ford use. Thanks
I am pretty sure that 70 is just the same as 69 and has independent clips that plug into the fender aprons that both go into.
Discussion Starter · #3 · (Edited)
I know that 70 is different from a 69, but I just don't know in what way! I think Ford used plastic ties. If anyone has a 70 Cougar would you please look at yours and let me know. Thanks
I don't think so, but let's see what others have to say.
Discussion Starter · #5 ·
This is from another forum. The 1970 Cougar uses the same style clip for the vacuum hoses. They are affixed to the hoses with black cloth tape wrapped around the hoses and clips on both sides of the clip. They also follow a somewhat different routing on the 1970 than the 1969.
Hope that helps.
