I have a 68 cougar and only the center light is blinking in the rear. I've tryed other boxes, relays and replaced turn signal switch with the harness but still the same problem. Sometime when you turn on the signals, left or right both side will blink as if the hazards were on, but if you turn it off and back on that side will blink. Any suggestion?
Thanks, Radcat
Thanks, Radcat
