Are there any new pieces available for the areas of the trunk floor around the gas tank. I pulled the tank out of my '68 today and found that the area across the front of the tank is no longer watertight. It is not real bad but is rusted through in a couple of spots.
If there are not any new pieces available, I do have a shell of a '68 that is not repairable that I could probably cut the pieces from, although they would require some work.
Thanks
Chris
www.theflagsaver.com
Thanks
Chris
