So I am trying to trouble shoot me sequentials and this is where I'm at.
I have no signals
Brake light and tail lights are fine
When i turn on the hazards and signals, the sequential motor is turning
If I remove the emergency warning relay at the end of the pigtail and hook up a voltmeter, it shows that there is power going into the relay (the meter pulses in time with the motor).
I am thinking that the hazard relay is bad, any ideas and can it be replaced?
Hopefully the picture i posted that show the emergency warning relay removed is attached.
Ok, so I've been reading the link above over and over trying to figure it out. I noticed that all 4 (3 rear/1 front) turnsignal bulbs must be good for them to work. So I went to check. All lights work as parking lights but do not blink. As soon as I turn on the headlights on, the front signal lights go out. I find this odd.
well i have read that and it doesnt quite seem to solve my problem. I have not turn signals or hazards but if i disconnect the relay at the end of the pigtail (not sure exactly which one it is) and test the pigtail, i get a voltage jump as if the turn signal is putting out the juice. Is there a way to test the relay to see if it is bad?
