Any one with TW heads know what size pushrods to use? Its a mild cam with 1.6 harland sharp rockers here is the cam info. Thanks Ron
Hydraulic flat tappetBasic Operating RPM Range
1,500-5,000Intake Duration at 050 inch Lift
216Exhaust Duration at 050 inch Lift
216Duration at 050 inch Lift
216 int./216 exh.Advertised Intake Duration
272Advertised Exhaust Duration
272Advertised Duration
272 int./272 exh.Intake Valve Lift with Factory Rocker Arm Ratio
0.484 in.Exhaust Valve Lift with Factory Rocker Arm Ratio
0.484 in.Valve Lift with Factory Rocker Arm Ratio
0.484 int./0.484 exh
Discussion Starter #2
I found the info
289/302 engines with any recommended rocker arm
Camshaft Type Pushrod Length
Hydraulic roller 6.750 in.
Hydraulic flat tappet 7.300 in.
351W Engine with any recommended rocker arm
Hydraulic roller 8.050 in.
Hydraulic flat tappet 8.600 in.
you must measure for correct length AND follow the install directions that come with the cylinder heads
trick flow has very easy to understand directions that in the box with the heads and are also avail. on line
short cutting will only cause massive damage
please buy the proper push rod lenghth tool to check height for your engine
+1...You are gambling alot there. Verify what length your engine needs.
