Hello. I am curious as to weather or not the stock transmission cooler for the c4 inside my radiator is up to the task of keeping an AOD cool. Also, can the cooling lines for the C4 be used at all for an AOD?
It would be wise to run a seperate tranny cooler, it reduces heat by 25% or so, and they arent that much. Not sure if the lines are the same. Arent AOD metric lines, not sure about that, but invest in a tranny cooler.
Rick
Whats an AOD and how does it differ from a FMX.?:confused:
Just use the stock stuff unless you're bumping up the convertor stall speed. The AOD has metric internals but standard cooling lines. You'll have to bend up your own lines to make it work.
