Three basic inputs are used to determine shift: throttle pressure (modulator), kickdown (linkage), and output speed (governor). Vacuum has to be connected to the intake manifold, throttle linkage has to be adjusted, and your speed will matter. I am assuming you are within the normal ****t down speeds so I would focus on linkage and vacuum.
