ouch!
sorry again, the 68 and 69 are not the same at all. the only part that will swap between 68 and 69 is the brake pedal. they are actually a little different but a 69 will fit a 68. i have not tried the other way so i can't say for sure. the 68 pedal has an extra bracket on it that does not actually do anything and it may hit if you use it on a 69. 67/8 clutch pedals won't work on 69/70 because of the design change of the dash which required a change to the over ride spring design. the 67/8 has a long hook end spring that is pulled as the pedal travels and the 69/70 uses a short compression spring with rollers on the ends. in reality all years of pedals are different up to 70. the 67 hang straight down around the narrow column, the 68's reach around the new wider column, the 69's have a revised hanger and over ride spring, and 70's are different again because of the new locking steering column and relocated power brake booster arm. if you have manual brakes 68-70 brake pedals are interchangeable and from what has been discussed here before i know you can swap 69/70 clutch pedals if you devise a bumper, the hangers will swap between 67 and 68 but 69 and 70 are year specific. to be truthful ford redesigned the pedals every year and there are 4 different clutch pedals, 10 different brake pedals (stick, auto, power and manual), 3 different hanger brackets, and two different clutch over ride springs. the only year swap that will work for sure without a problem is putting 68 pedals in a 67. hawkrod
