If we park the cougar in the garage we have to get out quickly as the fumes are overpowering, just from driving in and switching off.
[Finally cleaned out the garage to get the cougar in - for those of you who have read about my parking woes].
Reading something on a BOSS site I picked up this bit of info.
Okay, that seems to be our problem, here are the pictures of my intake manifold and carb [again], someone please confirm that the problem with the i.m is causing the problem with the carb, or are the two unrelated. And, if so - how so?My BOSS is running rich. I have rebuilt the carb and have tried to adjust the mixture, but it still smells very rich. I do not have a cross over tube on the exhaust, but the right bank is dry and the left bank is wet. The fumes are overpowering. A: If you have had the intake manifold off recently, retorque the bolts, then adjust the carb again. While leaking air into the induction system actually causes a lean condition, many people (I've done it too) adjust the carb to be rich to try to get it to idle before figuring out that a loose intake manifold was the problem.
