I worked for a couple hours this afternoon on my $300 Sidewinder intake. Installed eight helicoils to repair stripped valve cover bolt holes and the road draft tube hole cover bolts. Also had to grind reliefs into the area of the pushrod tubes where some gorilla used a prybar to remove the intake. Still need to drill and tap the PCV plumbing holes and plug the oil filer hole with a 1 1/4" core plug.
