1 - 15 of 15 Posts
Brand, size, whitewall, blackwall, etc.
mine are so old they are probably dangerous. but the front end is tight and needs an alignment and tires. appreciate your ideas. info and photo in the signature-
Discussion Starter #2
i should add the wheels are 14 inch Magnum 500's.
BFG Radial T/A's.
BFG Radial T/A's.
^^that^^ or... Do you have 14x6 or 14x7 Magnums? For 14x6, 215/70-14, but if 14x7 either 225/70-14 or 245/60-14.
I also like the Firestone Indy 500 in either 215- or 225-70 14.
good stuff Milo, thanks. i think they are 14x7. kinda' tough to tell with the tires still on, or is there an easy way? curious how you learned this info. i cannot find any decent gouge on the internet or in my shop manuals.
seems to look best with the raised white letters. thanks-
I have sets of both 14x6 and 14x7 painted Magnums. The trim rings are different, too, with the 14x7s using a deeper trim ring. If you measure your wheels, tell me what/where you're measuring I'll measure mine the same way.
i didn't know Magnums came with trim rings? i am measuring/estimating the distance between the edge of the rims where the tire bead sits-
Yep, the painted Magnums came with trim rings. These would be your basic Ranchero and Granada optional wheels.
Here's a pic of BetaCat from 20+ years ago wearing 14x6 painted Magnums in the front and 14x7 painted Magnums on the rear.
Yes, my 14x6s came from a Granada, and the 14x7s came from a mid-70s LTD II. I have complete sets of four of each. BetaCat's 'normal' tires/wheels are the 14x6s with 215/70-14, and I had mounted some fatter tires (G-60-14 or 245/60-14 in todayspeak) on the 14x7s and put those on the rear for better traction at the dragstrip.
I went with the Pepboys special Futura GTs 225 70 r 14's on my 70 but I fully intended to abuse them like there was no tommorrow. Not many 14" tires around these days.
I agree, although there's actually nothing wrong with using 225/70-14s on 14x6 wheels.
If you have 14x7s, the extra width of the 245s is nice, but the diameter is about 3/4" shorter than 225/70s. That's enough to be noticeable. I've used both in the past, and personally I prefer the way the 225/70s fill up the wheelwells a little more, at least from the side.
My two cents.
Are those still Cornel's?
You know I am not sure. They had a buy 3 get on free sale last summer and for $60 a tire I could not say no. I pretty much abuse them. Just keep in mind that in the rain they are not exactly safe LOL.
1 - 15 of 15 Posts
