1 - 11 of 11 Posts
My tie rods ends are wiggling and giggling al over the place, I mean its going to pop any day so I stopped driving it. Whats parts do I need to get things back in line?
I'm going to be doing a granada front disc brake swap, I already have the spindles and calipers and plan on buying some cross drilled rotors from www.Rotorsonline.com
Everything, as in all the tie rods, sleeves, and probably ball joints will likely need to be replaced if the tie rods are in that poor of a condition.
Buy a front end rebuild kit. It's not that expensive, and not really that difficult.
You'll need a ball joint tool, frequently called a pickle fork, and a bfh, some sockets, and a wrench or two, a pair of pliers for cotter pins, etc.
Check your strut rods too. They have bushings that wear and can crack from use.
Or, you can just replace the offending tie rods and see what happens from there.
Another option, is the free
<!-- START Header1CachedDisplay.jsp --><SCRIPT type=text/javascript> j(document).ready(function() { header1CachedDisplay_document_ready(); }); </SCRIPT><SCRIPT type=text/javascript> function setVehicleOnClickEvent(){if (j("div#vehicle-options").is(":visible")) { hideVehBox(); if (j("#addVehicleForm") && j.browser.msie && j.browser.version.substr(0,1) == 6) { setTimeout("j('#addVehicleForm select').show();", 2000); } } else { if (j("#addVehicleForm") && j.browser.msie && j.browser.version.substr(0,1) == 6) { j("#addVehicleForm select").hide(); } showVehBox(); if ( ! firstTimeLoad ) { firstTimeLoad = true; j('select#vehicleheader_year').attr('disabled', true); j('select#vehicleheader_year').html("<option value=''>Loading...</option>"); j('select#vehicleheader_make').attr('disabled', true); j('select#vehicleheader_model').attr('disabled', true); j('select#vehicleheader_engine').attr('disabled', true); j.get("FetchVehicleDetailsView", {YMMEAction: "wantYear", storeId: "10151", catalogId: "10051", langId: "-1"}, function(chMk){ j('select#vehicleheader_year').attr('disabled', false); j("select#vehicleheader_year").html(chMk); j("select#vehicleheader_make").html("<option value=''>Select Make</option>"); j("select#vehicleheader_model").html("<option value=''>Select Model</option>"); j("select#vehicleheader_engine").html("<option value=''>Select Engine</option>"); }); var params = {headerFirstLoad: "true" , fromHeader: "true" , storeId: "10151", catalogId: "10051", langId: "-1"}; if (j.cookie('CALL_CENTER_CUSTOMER_ID')) { params.customerUserId = j.cookie('CALL_CENTER_CUSTOMER_ID'); } j.get("AddVehicleView", params, function(mygarage){ j("#my-garage-vehiclemainWithLogReg").html(mygarage); }); } if (!cookiesAreEnabled()) { alert("You must allow site cookies (first-party cookies) to use the 'My Garage' vehicle selection feature. Please adjust your browser's privacy settings and retry."); return; } }} var pageOverrideObject = { pageSpecificFunctionSelVehicle: function () { reLoadOrSubmitPage(); }, pageSpecificFunctionEraseCookies: function () { reLoadOrSubmitPage(); }, pageSpecificFunMatchURLVehicle: function() { // if a page is not worried about vehicle id in URL then this function should be overwritten (or may be vice-versa TBD ) var oldVehicleCookieIsNull = false; if ( j.cookie('AAP_VEHICLE_ID') == null ) oldVehicleCookieIsNull = true; // TODO as of now this is working in only firefox. This feature is not required for 2/28 j.get("GetVehicleInfoView", {vehicleId: j.query.get('vehicleId'), storeId: "10151", catalogId: "10051", langId: "-1"}, function(xml){ // If we are not able to fetch vehicle description ignore url vehicle id. Some is wrong if(j("status",xml).text() == 'Success' ) { message = j("message",xml); if ( j.cookie('AAP_VEHICLE_DESC') != null && j.cookie('AAP_VEHICLE_DESC') != '' ) j("div#headerSuggOldVechDesc").html("Current vehicle is: " + j.cookie('AAP_VEHICLE_DESC')); j("div#headerSuggNewVechDesc").html("Old vehicle is: " + j("VehicleDesc",message).text()); SetVehicle_Cookie(j("VehicleId",message).text(), j("VehicleDesc",message).text(), j("VehicleCode",message).text(), j("VehicleMeta",message).text()); j('#headerDiffVehInURLCookie').modal(); j("#CachedHeaderAppVehicleCookie").html(j.cookie('AAP_VEHICLE_DESC').substring(0,27)+'...'); j("div#CachedHeaderCurrentVehicleInLayer").html(j.cookie('AAP_VEHICLE_DESC')); } else { if ( j.cookie('AAP_VEHICLE_DESC') != null && j.cookie('AAP_VEHICLE_DESC') != "" ) { j("#CachedHeaderAppVehicleCookie").html(j.cookie('AAP_VEHICLE_DESC').substring(0,27)+'...'); j("div#CachedHeaderCurrentVehicleInLayer").html(j.cookie('AAP_VEHICLE_DESC')); } else { j("#CachedHeaderAppVehicleCookie").html('All Parts'); j("div#CachedHeaderCurrentVehicleInLayer").html('Select Your Vehicle'); } } }); } }; j(document).ready(function(){ // To handle a scenario where old cookie is not same as new cookie //if ( j.query.get('vehicleId') != null && j.query.get('vehicleId') != '' && j.cookie('AAP_VEHICLE_ID') != j.query.get('vehicleId') ) //{ // pageOverrideObject.pageSpecificFunMatchURLVehicle(); //} //else //{ if ( j.cookie('AAP_VEHICLE_DESC') != null && j.cookie('AAP_VEHICLE_DESC') != "" ) { j("#CachedHeaderAppVehicleCookie").html(j.cookie('AAP_VEHICLE_DESC').substring(0,27)+'...'); j("div#CachedHeaderCurrentVehicleInLayer").html(j.cookie('AAP_VEHICLE_DESC')); } else { j("#CachedHeaderAppVehicleCookie").html('All Parts'); j("div#CachedHeaderCurrentVehicleInLayer").html('Select Your Vehicle'); } //} j("a#vehicle-close").click( function(event){ event.preventDefault(); hideVehBox(); if (j("#addVehicleForm") && j.browser.msie && j.browser.version.substr(0,1) == 6) { j("#addVehicleForm select").show("slow"); } } );//Remove hoverintnet var chooseVehcileConfig = { sensitivity: 3, // number = sensitivity threshold (must be 1 or higher) interval: 50, // number = milliseconds for onMouseOver polling interval over: doNothing, // function = onMouseOver callback (REQUIRED) timeout: 2000, // number = milliseconds delay before onMouseOut out: setVehcileOnClickSecond // function = onMouseOut callback (REQUIRED) }; j("div#your-vehicle").hoverIntent( chooseVehcileConfig );// j("a#vehicle-link").click(// function(event){// event.preventDefault(); // setVehicleOnClickEvent(); // },// function(event){ // event.preventDefault(); // setVehcileOnClickSecond(); // } // );});var pageReloadOnVehicleChange = false;function submitManageMyGarageHeaderForm(vehicleID,vehicleCODE){ document.ManageMyGarageHeader.vehicleID.value= vehicleID; document.ManageMyGarageHeader.deleteVehicle.value= "true"; document.ManageMyGarageHeader.vehicleCODE.value= vehicleCODE; j.get("ManageMyGarageCmd", {vehicleID: vehicleID, vehicleCODE: vehicleCODE , deleteVehicle: "true", storeId: "10151", catalogId: "10051", langId: "-1" , fromHeader: "true", URL: "AddVehicleView"}, function(chMd){ j("div#my-garage-vehiclemain").html(chMd); })} function submitaddVehicleHeaderForm(){ // check if cookies are enabled if (!cookiesAreEnabled()) { alert("You must allow site cookies (first-party cookies) to use the 'My Garage' vehicle selection feature. Please adjust your browser's privacy settings and retry."); return; } j("div#vehicle-buttons").html(""); if("" != document.addVehicleHeaderForm.vehicleheader_engine.value) { var vehicle_engine = document.addVehicleHeaderForm.vehicleheader_engine.value; var vehicle_ID = vehicle_engine.substr(0,(vehicle_engine).indexOf(":")); var vehicle_Code = vehicle_engine.substr((vehicle_engine).indexOf(":") + 1,(vehicle_engine).indexOf(":")-1); vehicle_engine = vehicle_engine.substr(vehicle_ID.length+vehicle_Code.length+2); document.addVehicleHeaderForm.vehicleDesc.value= document.addVehicleHeaderForm.vehicleheader_year.value + " " + document.addVehicleHeaderForm.vehicleheader_make.value + " " + document.addVehicleHeaderForm.vehicleheader_model.value + " " + vehicle_engine ; var vehicleMeta = document.addVehicleHeaderForm.vehicleheader_year.value + "|" + document.addVehicleHeaderForm.vehicleheader_make.value + "|" + document.addVehicleHeaderForm.vehicleheader_model.value ; document.addVehicleHeaderForm.vehicleID.value= vehicle_ID; document.addVehicleHeaderForm.vehicleCODE.value= vehicle_Code; SetVehicle_Cookie(document.addVehicleHeaderForm.vehicleID.value, document.addVehicleHeaderForm.vehicleDesc.value, document.addVehicleHeaderForm.vehicleCODE.value,vehicleMeta); resetHeaderCurrentVehicle(); //if(document.addVehicleHeaderForm.addToGarage.checked){ if (!j.cookie('CALL_CENTER_USER')) { j("div#vehicle-buttons").html("Saving..."); document.body.style.cursor = 'wait'; j.get("ManageMyGarageCmd", {vehicleID: vehicle_ID, vehicleDesc: document.addVehicleHeaderForm.vehicleDesc.value , vehicleCODE: vehicle_Code , storeId: "10151", catalogId: "10051", langId: "-1", URL: "AddVehicleView", fromHeader: "true"}, function(chMd2){ document.body.style.cursor = 'default'; if(chMd2.indexOf("The vehicle is already added to your garage.") > 0){ j("div#vehicle-buttons").html("Vehicle already added"); } else{ j("div#my-garage-vehiclemain").html(chMd2); j("div#vehicle-buttons").html("Vehicle added"); } resetYMMEDropDowns(); reloadPage(); hideVehBox(); }) } else { resetYMMEDropDowns(); reloadPage(); hideVehBox(); } /*} else { resetYMMEDropDowns(); reloadPage(); j("div#vehicle-options").slideUp("normal"); j("div#your-vehicle-min").removeAttr("style"); j("div#your-store-min").removeAttr("style"); j("div#your-account-min").removeAttr("style"); }*/ } else if ("" != document.addVehicleHeaderForm.vehicleheader_year.value) { var errorMsg = ""; errorMsg = "Engine"; if ( "" == document.addVehicleHeaderForm.vehicleheader_model.value ) { errorMsg = "Model, " + errorMsg; } if ( "" == document.addVehicleHeaderForm.vehicleheader_make.value ) { errorMsg = "Make, " + errorMsg; } j("div#vehicle-buttons").html(" Select " + errorMsg + ""); } else { hideVehBox(); } return false;} function resetYMMEDropDowns(){ j("select#vehicleheader_year").val(''); j("select#vehicleheader_make").html("<option value=''>Select Make</option>"); j('select#vehicleheader_make').attr('disabled', true); j("select#vehicleheader_model").html("<option value=''>Select Model</option>"); j('select#vehicleheader_model').attr('disabled', true); j("select#vehicleheader_engine").html("<option value=''>Select Engine</option>"); j('select#vehicleheader_engine').attr('disabled', true); j("div#vehicle-buttons").html(""); }function resetHeaderCurrentVehicle(){ if ( Get_Cookie( "AAP_VEHICLE_DESC" ) ) { j("#CachedHeaderAppVehicleCookie").html(j.cookie('AAP_VEHICLE_DESC').substring(0,27)+'...'); j("div#CachedHeaderCurrentVehicleInLayer").html(j.cookie('AAP_VEHICLE_DESC')); } else{ j("#CachedHeaderAppVehicleCookie").html("All Parts"); j("div#CachedHeaderCurrentVehicleInLayer").html('Select Your Vehicle'); } if ( j.query.get('vehicleId') ) { modifyURL(); }}</SCRIPT>
FREE Loaner Tools
From spring compressors to specialized pullers and more, we’re here to help with the tools you need to get the job done right. Deposit required.
The deposit is full price for the tools. If you decide to bring them back they will give you a full refund.
Not a bad deal at all. That's what I did when I replaced my 93 Cougar front susp.
Word of caution, tie rod ends and other suspension parts that have been on 40+ years are hard to get off even with a pickle fork. I hammered away for at least an hour on each one. But I don't have a lot of bodyweight behind me...so go figure. I broke 2 tie rod end removers trying to take them off, so I stuck with hammering at the pickle fork. Renting parts from the store is a PITA when they want $100 deposit for the tools you need...when you don't have $100. Have fun with it though.
Those pullers look a little more robust then what I got off the shelf at the parts store. What are they making the ones on the shelf from that makes them break so easy?
Catman where did you find that set and how much for it?
I just used the kit that Advance Auto Parts had which looked the same as the picture I posted from this site.
http://www.brandsplace.com/tool-automotive-repair-strut---spring-tools.html
The kit at Advance Auto was a little over a hundred bucks but I got all the money back when I returned it.
Brandon's right the picture of the kit does look thicker than the ones I rented but they worked. Maybe I just got lucky because the parts I removed were only on the 93 Cougar for 17 years. I had one ball joint that gave me some trouble so I removed the tool and heated up the ball joint with a propane torch, put the tool back on and it popped right off.
1 - 11 of 11 Posts
