1 - 19 of 19 Posts
ill stick the camera into places my fat head wont fit. after looking at the pics i find what looks like a crack in the head. is this from over torqueing the fasteners?
DANG!
Whatever caused it, now you have to pull the head. Bummer!
no big deal. need a valve job anyway.
I have a set of 2v heads on the parts car with the stock exhausts,
I think this is a good excuse to pull all four heads.
(serentiy now, serentiy now)
I thought you were excited to have a 4v motor, now your going to put 2v heads on it????? That head can be fixed, no big deal. mm
Looks like bolt used was too long and bottomed out. Easy fix when pulled off. Weld up and install thread insert.
I looked at today after work and could not see a crack, so i wire brushed it and used a mirror to look again, still no crack. must have been a dang shadow from the camera angle.
4v heads wooohoooooooooooooo.
hell of a shadow.
Hey Bowl,
I hope you are right about the shadow, but that shadow looks like it's got a rust ring around it.... A dead giveaway for a crack. It would be wise to pull the head, especially if you would like to freshen them up, and have them crack checked.
I had a small block head welded up, after the job was done it was staighter than the other one!! The slow heat-up-cool-down process that the good cast welders use stress relieves the iron.
I hope I'm not being negative here, I just hate to see a guy go through a bunch of work only to have to take it all apart again.... But I'M NOT BITTER ABOUT IT!!!! I think I had my C4 together and apart 4 times before I put the flarn thing back in the car... learned some lifelong valuable lessons on that one.
Ron.
Bowl take another picture now tht you have cleaned it up, sure looks like a crack to me, and specially with all that rust around it.
Looks like a shadow from the pocket arounf the plug to me. My 2 cents.
Bowl, is this the crack you are referring to?
Discussion Starter #12
before cleaning it from a diff angle and no shadow
Discussion Starter #13
cleaned
By crackie I think that was a shadow... It's hard to see the recessed flange condition on the first photo, looks just like a crack with a rust ring. You had just enough of an angle between the flash and the shutter that the flash caused the little shadow that looked like the crack... Just goes to show... Things are not always as they may first appear.
Ron.
Here's an image of it, in negative.
Now it looks like a crack in the negative. hummm, do you pull the head and check it out, or do you continue on with your day and drink another beer. :)
Rick
At least drink another beer while you're thinking about what to do:)
Discussion Starter #18
the head is good on my 351 and my Shiner Bock (best beer ever)
they started selling kegs of Shiner in CA during my junior year in college ('98-'99) hee hee... I remember SOME of that year...
1 - 19 of 19 Posts
