Hello all! When I start my 69 Std, The temp gauge spikes to "H". When I shut down, it goes all the way down. What do you all think, Gauge or Sender?
Thanks,
David
69 Cougar Conv.
66 T-Bird Conv
65 GTO Conv
70 GTO JUDGE Conv.
67 Dart GTS Conv
70 AAR CUDA
2002 Indian Chief Deluxe
replace the sender 1st then if it continues replace the gague, at least you know it`ll be fixed. The sending unit is 20.00 from MU. to me sounds like a bad temperature sending unit.
thanks
pat
You might also want to check for a short in the harness between the sending unit and the gauge. Just turn the key on, and see what the gauge does.
Discussion Starter · #4 ·
When i turn the key to the "On" position the gauge spikes.
David
Unplug the sender, the gauge needle shouldn't move. If it does, you either have a short in the harness or a bad gauge. If it pins when you plug the sender in, then sender is bad..Are the rest of your gauges working properly? If not ,then check the voltage regulater on the back of the gauge assy...Hope this helps..
Bruce
