Well Jeff,
There can be many causes to this problem, most common is a fuse or broken wire.
Bad grounds can also cause this as can a number of small things.
Need to know a few things first.
A: What year Cat we talking
B: When did it stop and what were the circumstances.
C: Have you added anthing to the car?
PLMK and we can go from there.
:D
well its a 69 xr-7, when I got the car the tack didn't work, and the only thing I've don was put a new gas tank in it, new valve covers,a new air cleanerand a new sequencial chip in it.
I had problems with my tach, I traced it to a missing ground strap from the firewall to the engine but it killed my tach and I had to replace it. Another thing that happens is the solder joints inside the tach go bad, in that case all you need to do is resolder them.
Good Luck
John
