I just bought a 67 XR7 that someone installed a MSD ignition system. It has a 289 4V and I need to know if the tach is a voltage triggered or current triggered. It seems as though I will be spending more to fix things that the previous owner did than anything else. Thanks
Yes, but it only goes up to about 600 rpm. There is a MSD tach adapter installed but I don't know how to rewire it unless I find out about the trigger for the tach. thanks.
I was in your postion many years ago. Tach is current triggered. But no matter what I did wiring up the correct MSD adapter, my tach NEVER worked right until...................
I got in touch with Rocketman and had him convert my stock tach to work with the MSD box and it has been flawless ever since.
http://www.rccinnovations.com/
FYI, Bob is in the process of moving his entire operation halfway across the country. So he's currently shut down for about two more weeks. It'll be WELL worth the wait.
