Almost completed the T5 swap in my 67 with a 289. I can not get a manual shift starter to bolt up, the automatic will bolt up, but will it work?. Did you know a drive shaft from a 68 falcon 4 door is a direct bolt in for the T5 swap? I do have some fitment issues around the shifter hole I need to deal with. Installed all new motor mounts to 68 lower mounts. Tomorrow morning I'll recheck all the mounts and fluids. Hopefully my z bar bushings that were backordered will come tomorrow, and I might be able to drive it this weekend. As always, thanks for your help. GReg
