1 - 12 of 12 Posts
How do I know what size sway bar do I have. How do I figure this out....Lance
Use a open end wrench. Put the open end over the bar. A 7/8" wrench fitting = a 7/8" bar
Thanks wasn't to sure how to go about it. Lance
what size sway bars were used in 68 cause i tried 7/8 no go then I tried 11/16..no go I dont have any open wrenches bigger..I think it measures 3/4 but I don't know....the 11/16 almost fit, but the 7/8 was way off....any suggestions...Thanks Lance
ok, grab an adjustable wrench, then measure the opening after you tighten the wrench on the bar.
Rick
tried that was there a 3/4 front sway bar in 68?
Yes, I believe that is the size for a non GT cougar.. Evilmess has the same size in his 68... I have the GT size in my 67 ( just under 1 inch). Are you going to replace it or did you just want to know what size you had...
Bruce
I want to order my front rebuild kit from americanpony and they need the diameter. I want to put in 3/4 but dont want to buy the wrong kit...Lance
Glad to help. Post some pictures, if you haven't allready...
Bruce
1 - 12 of 12 Posts
