How deep are your pockets? Here are a few simple and inexpensive items to check and replace if needed. Strut rod bushings; are yours cracked and weathered, if they are spongy they'll change the toe angle during lane changes. Power steering cylinder bushings; when the rubber is tired and cracked, it will contribute to sloppy steering control. Power steering ball stud assembly on the control valve: also contributes to sloppy steering, IMO a weak link. Idler arm assembly: this is a big one, it is what all the steering linkage pushes against, you don't what any play here at all! Lower control arm eccentrics: another weak link, upgrade to the plate type and don't look back! What's left?? The heavy hardware!! Steering boxes, upper and lower control arms, tie rods, ball joints and misc. connecting hardware. x2 on getting quality components,..... poor quality rubber and ill fitting tapers and thread patterns, are so much scrap metal. See you around the Front Range sometime!
