Well, as promised, I am starting a new thread to cover the 331 buildup. I have all (most...knock on wood) my ducks in a row and will start assembly this weekend. I have taken a few precursory pictures of the gear as well as a list of the specific parts. Prior to beginning this, I do need to thank Art for providing time and advise on some of the parts. Thanks Art!
First off is the prepped block. 65 289 block .040 over, painted what I think is going to look good with the TW heads after I get them polished up. (of note in the first pic is the 4R70W).
Of note in the second besides the crappy resolution of the paint, are the '03 Bullitt wheels.
Here are several pics of the parts. Since I am limited to 5 pictures per post, I'll follow this post up with the intake, heads, carb and dizzy pics.
The Centech is my HF Calipers... The Slender White box is the Trick Flow Stage 1 Cam.
7k Hydraulic Roller lifters in the foreground (opposite side from the above pic)
Straight on shot, after "learning" about wrist pins by stabbing myself, I stopped at the 2nd piston/connecting rod mockup. I need to wait until I am prepared to complete them all anyhow as they need lubed.
Here is the parts list:
Short Block
New Eagle Cast Steel Crankshaft
New Eagle SIR Lightweight Steel I Beam Connecting Rods ( Bushed Fit Pins)
Keith Black Hypereutectic Pistons (matched Rods and Pistons balanced to within .5 grams heaviest to lightest, I already paired them)
Mahle Plasma-Moly Piston Ring Set with oil rail support rings
Clevite 77 Performance rod and main bearing set
28oz Harmonic Balancer and Flexplate (164 tooth for the 4R70W)
Rotating Kit's are External Balanced 28oz, +/-2 Gram balance on pistons and rods, 1/2 gram or less on crankshaft balance, bobweight balance card included.
Summit Racing High Volume Oil Pump
Top End
Trick Flow Twisted Wedge 170cc (TFS-51400004)
Trick Flow Stage 1 Hydraulic Roller Cam
Doug Herbert 7000 rpm Hyraulic roller lifters (link bar retrofit)
Profession Products Cyclone Chrome Intake
Pertronix HEI Distributor (Still need to swap gear for roller)
Summit 600 cfm Electric Choke, Vacuum Secondary 4 Barrel Carb
K&N Off base filter and top filter
Summit Racing 110 gph mechanical fuel pump
Misc. Parts
Summit Racing High-Volume water pump
New Aluminum timing Chain Cover
Summit Racing Double Roller timing chain and gears
New Camshaft eccentrics
Profession Products Stainless Steel Engine Bolt Kit
ARP Head Bolts
ARP Rod Bolts
ARP Oil pump stud
Remaining Bolts are all new
Short Block
Top End
Misc. Parts
ARP Head Bolts
ARP Rod Bolts
ARP Oil pump stud
