You could start with 6, drive it, see how runs, then bump it up to 8, drive it, and so on. When you get to the point you have a little spark knock during a hard pull, back it down to the last setting and you are good to go. The gasoline you use plays a part in this also, you can bump the timing up more with Hi test than with regular.
