LOL! I should have known THIS was coming......
Long story short, mine is from a late 70s Toyota Cressida wagon. But they're pretty much all the same. Later model Isuzu boxes work too and should be easier to find. I notched the subframe rail slightly, notched the shock tower slightly, shortened the column about an inch and a half and modified the rag joint to match up with the yoke. The pitman arm is a hybrid, half Toyota and half Ford. I used a manual steering Cougar center link.
Between the junkyard steering box and some adapters for the pressure hose, I have less than $50 in the whole swap. I did this back in 1993 while the engine was out of the car. I had no idea that other people had done this same swap on other classic Fords to get rid of the slave cylinder and associated parts. I thought I was going to be the Lone Wolf on this. Turns out I wasn't.
Short story longer...... It clears the headers well and eliminates the drop down bracket mod that's required for headers. I never even rebuilt the box and it has never leaked a drop of fluid. I'm about at the end of the adjustment range on the "sloppiness" scale so I sourced another one from a salvage yard out west. I've since had this new one rebuilt and I plan to swap it in this coming winter along with a universal joint to replace the rag joint. I've gone over 30K miles with this and have NEVER had an issue except for one blown pressure hose that I've since re-routed and it's been trouble free ever since.
Please don't ask for pictures. I did this at a time when I was not documenting anything as I went along. I could try to snap a pic of it in the car now.... but the car is parked in the corner of the shop for the winter as of this past weekend.
However........ if you sift through this lengthy thread, there is some helpful info in it regarding the swap as well as some good pictures from another member who took what I did and went 100X better.
http://www.mercurycougar.net/forums...P.S.-conversion&highlight=toyota+steering+box
