1 - 8 of 8 Posts
Tuned the cat (73 xr7 351c, stock 2bbl carb) 2 weeks ago.... smmoooth. Yesterday wife noticed it was wanting to stall when slowing. I drove it abound the block, sure enough it would stall if lots of gas was not given. I checked the Fuel Filter- OK I'm thinking:
Pertronix possibly shorted so its ok at throttle;but wont maintain idle? OR Power Valve/accelerator pum need replacing- any thoughts here? OR coil?-would this allow it to run at higher speeds but stall at idle? Thats it for a jump off point- I'll add that the timing was just set at 6 BTDC; but now shows at 21BTDC whats with that? HELP, HELP.
Thanks, Ed
Could be a bad distributor also.
Did you time the motor with the vac advance disconnected? Both times?
Super Moderator
Sounds like the timing chain jumped a few links, when was the last time you changed it?
That was my thought. Wasn't sure if he timed it the same way both times or not.
Discussion Starter · #8 ·
So far...
I looked over the vacuum lines and found a big leak where a hose was torn at the carb. Cleaned the carb, changed out some lines(vac.) Ran well on test last night- thought the prob was fixed... This AM the wife drove it breakfast with no probs, then on the way home, same deal needs plenty of gas or it will start to stall and eventually die- any last thoughts before I break the seal on the CARB REBUILD kit?
1 - 8 of 8 Posts
