Hi guys,
It started out as a carb/intake/cam install for my 351w. When the motor got put back together, I had a large oil leak. I pull the motor out and the cam plug got pushed out with the cam install. So while motor is out I replace the freeze plugs as well. I got the motor back in and wired everything back up as it was before.
Now when I turn the key the motor turns over but never starts. If u run a wire from the coil to the battery it fires right up.
Here is what I've done to try to find the problem
I replaced the ignitor 2 kit
I replaced the MSD blaster 2 coil because I had it tested and it was bad
I replaced the voltage regulator
I replaced the ignition switch
I'm out of ideas. All the grounds are good, everything is hooked up. I don't understand why it just doesn't start. It ran/started fine before I pulled it. What else should I look for. Anything will help. Thanks
