1 - 2 of 2 Posts
Well, I'm attempting to get an electronic ignition system working on my '67 Cougar and I seem to have a new problem that just snuck in today. After putting all the pieces back together, I was trying to start the car and after the third or fourth attempt at cranking the engine, the starter stuck on. I took the key out but it kept turning over. I pulled the negative battery cable to make it stop. This led to an extremely loud sound like a shotgun and a lot of smoke. I presume the noise and smoke came from a major arc from all the power the starter was pulling. I rehooked the cable and tried starting the car again. After a few attempts the starter stuck on again. I guess the solenoid has probably gone bad, but I tend to analyze everything to death. Does this indicate a bad solenoid? Or could it be that somehow the wiring has gotten messed up in such a way that the power from the ignition terminal on the solenoid is feeding the start terminal to keep the solenoid engaged? Any thoughts would be appreciated.
Thanks,
I'd replace the solenoid. Mine did this once, and that's what it was for me anyway...
Also, if you're running a aftermarket one-wire alternator, you need to hook up the S-terminal from the one-wire with a in-line diode...
1 - 2 of 2 Posts
