Anyone know if the speaker pods for the front mount through from the inside or mount to the outside? Got a pair from ebay, but can't find any mounting info. Thanks
If you have the custom front kick pannels you would install from the outside 6" speaker nut on the inside, then pop on the grill . Without any more info thats all I have for you. If you have the stock kick pannel I believe it would be the same you have to have the speaker exposed to get the grill on.
If you mean factory speaker pods for a 67-68 they mount from the inside through holes under the kick panels. They have to be cut first. The right one requires you to remove the heater or A/C box to get the pod in.
Thats my fault....it's a 67 with the cut out's for the kick panel. Thanks for the info....the car is stripped so the a/c box isn't a problem. It's going back together and wanted to mount these before putting the fenders back on or a/c box in depending on which they mounted.
