ZI got a quote from a new tire/suspension shop for rear wheel wheel bearings.
1st call $880.00 for bearings and a front brake hose. I thought it was high. He calls right back and says it actually is $1060.
He sends over an estimate for FRONT wheel bearings/oil flush/ hose.
I spoke with the appointment desk and told him REAR. At the time of the drop-off I describe the noise coming from the REAR.
He said he could not source several parts, but was able to get front bearing- though I have no indication that they need replacement.
Seems sketchy- quoted $148. for the inspection. I'm thinking I should cut losses?
Any ideas on what REAR wheel bearings on my '73 should run at a shop?
All parts are easily available to completely rebuild the rear end .. The question is.. is it just a axle bearing or is it internal as in pinion and or carrier bearings that are causing your noise? .. I would find another shop .. quickly..
A pair of rear wheel bearings is something like $100 including seals and gaskets. Installation is maybe 2 hours if the guy is slow and lazy. What's the other $700 for?
could your differential breather tube be plugged? Happened to me and I thought the wheels might be the problem. Whining around 60-70mph.
suspension place noticed that when adding a leaf and fixed it.
True, breather tubes have a fairly small hole inside. About 0.062".
