I read through the archives and I read related post. Yet I have no answer that seems black and white to my flippen analytical mind.<?xml:namespace prefix = o ns = "urn:schemas-microsoft-com
ffice
ffice" /><o
></o
<o
> </o
Synthetics vs Dinosaur oil. In the literature that I’ve ready it seems that American Petroleum industry had messed around with standard Dinosaur oils so that it is “Environmentally safer”, works better with catalytic converters and EGR stuff. In doing this they decreases the Zinc Phosphate which is basically the slippery stuff to minimize wear.<o
></o
For those us driving stock engines from the 60’ 70’ 80’ without roller lifter/cam, I have read that the lack of Zinc Phosphate can cause addition wear on parts.<o
></o
<o
> </o
><o
> </o
I started using synthetics in hopes of minimizing wear on my engine which had at the time 130,000 miles on it. I still change the oil regularly, just because there is over 130,000 miles on it. As far as leaks, it is a 289 4v and it is my understanding that these engines have been known to leak with 40 year and the original factory seals still inplace, as probably 50% of most vintage vehicles do.<o
></o
<o
> </o
I would stay with a high grade synthetic if it wasn’t for one comment I read last week.
The following is an excerpt from this Article I found on the internet written by Tom TorbJornsen , Maintenance Editor, AOL Autos.<o
></o
Disclaimer I have no clue of this guy’s credentials, or who he is. Nor do I know anything about AOL Autos.<o
></o
<o
> </o
The question:<o
></o
Q: Should I use Synthetic oil in my car?<o
></o
A: That depends on the vehicles age and the carmakers recommendation. Older vehicles with high mileages tend to have excessive mechanical wear in the engine, allowing for internal oil leakage. For vehicles with high mileage ,it is not recommended to use full synthetic oil because it is thin and very free flowing, and use of it results in oil consumption” <o
></o
<o
> </o
<o
> </o
First does anyone have an example of what “internal oil leakage”? Would this be like valve seats leaking or oil blowing past the rings?<o
></o
<o
> </o
The next question is, if a vehicle started with regular oil than went to synthetic, can it go back to a regular oil or a high mileage oil without any major issues?<o
></o
<o
<o
<o
<o
The question:<o
<o
<o
<o
