Hey guys. Can someone take 5min and check the angles of your pitman arm and idler arm? (pwr steering or not)
The alignment shop cant get my cat aligned, so I suspect that my manual steering adapter needs to be unthreaded a few turns.
What I need to know is if the idler arm is straight and the pitman arm is straight when the tires are pointed ahead.
Keep in mind that the pitman arm is curved, so you have to look at the 2 studs that hold it on to see if they are in line.
Thanks for your help!
